Bascially what the titles says. I am also hiping for cheap, I have heard to avoid boxed and poly bushings, I was thinkign of maybe just going with 1Les.
What LACA/Panhard rod do you guys suggest for AutoX?
<blockquote>quote:</font><hr>Originally posted by Dom:
1LEs or Rod ends. You probably just need a single rod ended ones. LG Motorsports and Billingsley racing carry them. BMR and Spohn use real cheap rod ends that make noise and wear out fast.<hr></blockquote>
BMR and Spohn use cheap rod ends ? I know that good rod ends have teflon lining to extend life, reduce noise and reduce friction. If you want, buy a BMR or Spohn or any other adjustable thread ended panhard or trailing arm and buy quality rod ends from a good distributor. Jegs has QA1 rod ends in several different styles.
I'm going w/the 1LE LCA's & PHR for my setup (already have the 1LE front & rear sway bars & BMR STB installed). Can't go too wrong w/stuff GM actually designed for autocross & roadracing ;)2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
I still think for the price, the BMR stuff when used properly is superior to the U-bend steel that GM uses...
But you can't go wrong with 1LE, wheras you can put yourself in a hurt locker with the BMR if you dont know what youre doing when choosing parts.2002 5-spd NBM Camaro
Details: www.1lev6.com
<blockquote>quote:</font><hr>Originally posted by 95silver:
BMR and Spohn use cheap rod ends ? I know that good rod ends have teflon lining to extend life, reduce noise and reduce friction. If you want, buy a BMR or Spohn or any other adjustable thread ended panhard or trailing arm and buy quality rod ends from a good distributor. Jegs has QA1 rod ends in several different styles.<hr></blockquote>
So you want to buy the cheap rod ended LCAs then on top of that pay for another set of rod ends, $30 a piece or more. So that's $30 times 4, another $120 plus whatever the BMRs are. Why not just get LG Motorsports ones?
If anyone wants the LGMotorsports G2 parts I will give them 10% off. Maybee this will help?<a href=\"http://www.lmperformance.com\" target=\"_blank\">LMPerformance</a><br /> <a href=\"mailto:Sales@LMPerformance.com\">Sales@LMPe rformance.com</a>
So you want to buy the cheap rod ended LCAs then on top of that pay for another set of rod ends, $30 a piece or more. So that's $30 times 4, another $120 plus whatever the BMRs are. Why not just get LG Motorsports ones?<hr></blockquote>
Are the LG rod ends superior to BMRs? What does LG use? They only make poly/rod combo arms. Their stuff is very expensive :( . Maybe they can charge more because they make better quality parts . I say just leave the stock parts on unless you have very large rear tires or some custom lowered autox car :D . Im sure that the aftermarket suspension doesn't make that much of a difference ;) .
Yes, the rod ends are of much higher quality and therefore more expensive. That means that they will last much longer and be quiet. Everyone I talked to so far hasn't heard a noise out of them. Same goes for Billingsley. http://www.billingsleyracing.biz/ One person here got the LCA and panhard rod and they are noise free. I will take a look at them myself at the next meeting. They have a special now $300 for the combo LCA and PHR. You can pick singe or double rod ends.
[ May 01, 2002: Message edited by: Dom ]</p>
