Steering feels lose! - FirebirdV6.com/CamaroV6.com Message Board
  • Steering feels lose!
    When I drive the steering has a lot of play in it, and I constantly have to correct it.....anyone know what could cause this?
    I had cheap tires once that made the car "wander" on the highway. Better tires, better handling. Alignment out-of-whack, worn busings, worn balljoints, etc. can be the culprit too.
    edit: forgot to add, I bought a "steering knuckle kit" on ebay that helped out ALOT! It replaced the old rubber washer (that fits on the steering shaft where the universal joint next to the driver's side of the engine) with a heavy duty rubber/metal material. It helped take most of the wandering away.
    [ January 31, 2005, 03:23 PM: Message edited by: hockeyman ]
      It looks like this: http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WD1V
      This is for an earlier style camaro, but it's basically the same thing I installed.
        Rag Joint Eliminator (1993-1997)
        http://www.unbalancedengineering.com/Camaro/
        Raven
          check for worn parts and make sure that if you have power steering that it is full and in working order. Steering is one of those things that you definatly don't go cheap on.
          255/50R16 Tires, Pioneer Deck, Pioneer 4 Way speakers, PPI Amps, JL subs, Spec Stage 3 Clutch, Optima Yellow Top
            Any info on this being also for the 98-99 V6 since they have the same rack as an LT1? (Which is why I assume they say only 93-97). My steering sucks.
              Originally posted by PiLOTLiTE:
              </font><blockquote>quote:</font><hr />Originally posted by FirebirdGT:
              Any info on this being also for the 98-99 V6 since they have the same rack as an LT1? (Which is why I assume they say only 93-97). My steering sucks. </font>[/QUOTE]No, but it should work as you point out it is the same as the LT1. Call Unbalanced Engineering.
              Raven
