V8 Springs on a V6? - FirebirdV6.com/CamaroV6.com Message Board
V8 Springs on a V6?
  • V8 Springs on a V6?
    I got a set of lowering springs, but theyre for a v8...does it really matter?
    Im thinkin maybe theyre just a little more heavy duty?
    <a href=\"http://www.redlinevsix.com/blackbird.html\" target=\"_blank\">Blackbird</a><br />RedLineVSix Co-Vice President <br /><a href=\"http://www.RedLineVSix.com\" target=\"_blank\">www.RedLineVSix.com</a><p>BlackBird903@hotmail.com<p>AIM: Alpinestar05
    If I knew I'd help you out maybe someone will reply sooner or later with a definate answer!
    .....they do use v6 springs on v8's sometimes so I don't see why not!
    Good luck with em though [img]smile.gif[/img]
    [ May 01, 2002: Message edited by: Nachius ]</p>
      What springs did you get? Im pretty sure they will fit as long as they are the same year of car. Like 98-02 and yours is a 98-02, I think the 97 and lower have different springs then the newer cars. I know when I was searching for springs I fount a set of coil overs that were for a 98 LS1 car but they will still fit my car. I am pretty sure most of the Eibach springs will fit too. It may just have a different drop height then on a V8 car due to the weight difference.
        Spring installs are usually the same especially on all 4th gens.
        The only difference you will see is in the ride height. The engines all weigh differently affecting the springs compression.
        FRANKLIN H. <br />1995 Silver Camaro L32 <br />K&N,Flowmaster,HPP,160*,1LE,Zexel-Torsen,ES,BFG,Michelin,Bilstein,Eibach,C5 rims,!CAT,!AC
          v8 lowering springs probably wont lower your ride height much. when/if you put them on, get some pictures up because this is only what I've heard over the past couple years on web forums and I want to see for myself! [img]smile.gif[/img]
          1994 Camaro 3.4L M5 R.I.P.<br />You know what they say- a small engine means big... errr... e/t\'s<br /><a href=\"http://www.pbase.com/rrj72/the_accident\" target=\"_blank\">www.pbase.com/rrj72/the_accident</a><p>replaced with: red 97 A4 vert (my brothers as soon as i find my REAL replacement)<p>soon to come: 1969 RS/SS<p>\"All you need are the esentials: scented candles, massage oil, and Berry White write that down.\" -Van Wilder
            Well i dont know if i wanna put $200 bucks into this install and have my car only drop 1/4 or half inch.
            if that happened, then id have to pay for new ones, plus another 200 install..
            I'm gonna wait a few days and ask around..
              SEND THEM BACK
              Think about it--V8 cars weigh more, right? So if you install them on a lighter car, they won't go down as far as they will for a V8. Get the springs that are for a V6, and then all will be good.
              The reason V6 springs are used on V8 cars a lot is because the V6 ones aren't used to that much weight on them and it produces more weight on the wheels. More weight on the wheels=more traction on launches. I sold my rear V6 springs to a V8 guy, but no one wants the front ones, cause its not the change of ride hieght V8ers are looking for its the drag ability.
              Hope this helps!
              Jeremy
              [ May 02, 2002: Message edited by: red blur ]</p>
              <a href=\"http://community.webshots.com/album/132472073VSLipP\" target=\"_blank\">1997 Cayenne Red Metallic Z-28</a> <br /><b>BMR</b> SFCs, STB, PHR, LCAs, relocation brackets, <b>1LE</b> 32/21 mm sway bars, Eibach Pro-Kit, SLP fan switch<br /><br />red 96 v6 M5 -- <b>SOLD!!!!</b><br /><b> I DO T-TOP CONVERSIONS!!!</b> <a href=\"http://community.webshots.com/user/v6blur\" target=\"_blank\"> LOOK HERE!!!</a>
