Well my car has been acting funny lately. When i start her up in the morning and come to the first two stopsigns by my house i press the brakes but as im pressing they seem to give and the Low Trac light comes on. It seems to do it alot. Its like i brake low trac light comes on seems like have to press the brake harder and then it stops. If i press the brake firmer after the lOw trac light is on it goes into ABS INOP and it is fine and the ABS INOP stays on and my car doesn't do low trac anymore. Any thoughts as to why this could be?
Brakes..Low Trac..ABS INOP..Need some help
Might be your master cylinder or a line or such.2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
have you checked the brake fluid level?Justin96Bird / Justin98TransAm<p>1998 Navy Blue TransAm<p>Whisper Lid<br />free ram air<br />K&N Filter<br /><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">DynoMouth Exhaust</a><p><a href=\"http://www.hhbc.com/justin96bird/index.htm\" target=\"_blank\">http://www.hhbc.com/justin96bird/index.htm</a>
Yep, brake fluid is just fine. I'm thinking that maybe the pads are getting low or something. I'm gonna go to a brake place soon. NOT "Just brakes" Dont go there [img]smile.gif[/img] Alright anyone else with some insight?<a href=\"http://www.saintsworth.com/z06\" target=\"_blank\">\'02 Corvette Z06</a>
It's not the pads either, I got them replaced, but still had the same problem. The mechanic told me I should go to the dealer, but I have to drop my car in the early morning, and they rip you off like a mo fo. My mechanic guess it might be the air bubble in the brake line, but still can't figure out why.
How's your suspension? I have bad springs and maybe it's due to uneven weigh ratio on each wheels?
I'm getting new springs... they're on the way.Sunny Cali, T-top is the way to go! \'96 V6 3.8.
I had the same problem. I was told by my mechanic that the abs modules are known to go bad after a while and a new one would run somewhere around 1000-1500. I just pulled the fuses to get rid of the annoying flashing of the abs inop and low trac lights, and besides I like my car better w/out ABS. Just have to be careful in the rain.1993 3.4 <br />Borla rear section<br />3 inch Catco High Flow Cat<br />2.75 inch I pipe (Picked one up from an LT-1 guy for a whole $10)<br />K&N Fipk <br />180° T-stat<br />Jet Stage II<br />10 Spoke Z28 Wheels<br />NGK\'s, Taylor Spiros<br />Mobil 1 synthetic<p>Email Viper2@chesnet.net for 4th gen replacement parts.
It only happens in the morning's from what I can tell. Its a pain..Were is the ABS sensor wire. I looked around the wheel and wheel well and didn't see anything. Please Advise<a href=\"http://www.saintsworth.com/z06\" target=\"_blank\">\'02 Corvette Z06</a>
Something else you could check is your tires. If they are bald and/or your rotors are warped, you might actually be sliding a tire when you come to those stop signs. Tires don't grip very well when they are cold.\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
My tires are brand new Toyo Proxes big beast tires [img]smile.gif[/img] Z rated...It also guys makes a Noise when my windows are down i can hear it when i press the break its like a squeaky low noise and like a cracking kinda.. THis cant be good.<a href=\"http://www.saintsworth.com/z06\" target=\"_blank\">\'02 Corvette Z06</a>
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
