Tonight I was leaving a parking lot going slowly around a corner and suddenly, the power steering fails. I knew what it was right away, so I stopped to check it out. The check gauges light is on, so I open the door and close it, then the light goes off as the door closes. I check my fluid pretty often, and I know I wasn't near running low. I then move the wheel some, and everything is fine so I go on my way and have no problems. I had the check engine light go on for no reason once before, so I stopped, restarted the engine and it was off, everything was fine. Anyone know what would cause the steering to fail for just a minute. I'll check the fluid tomorrow morning, but I'm thinking it is a computer problem due to the light coming on. any advice?
power steering problem
belt slipping maybe? possibly the belt or tensioner i guess. this would cause a charging problem and make check gauges illuminate. check gauges cant tell anything about the power steering -- just oil pressure, charging voltage, and fuel level.
Yeah, I'm definately thinking it was the belt slipping, that explanation makes the most sense. Haven't had any problems since. Is this something worth getting looked at?\'95 3.4 metallic teal Camaro- t-boned by an F-250, sold and still runnin\' somewhere out there...<br /><br />\'96 3.8 metallic teal camaro<br /><br />...Lookin for black 6 speed Z28 or Trans Am...
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...4 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
