I tried to search on tis but could not find anything. Well I was wondering if anyone on here has changed there rear drum brakes in to disk brakes all around for (93-97 i think)?? If so how hard was it and how mcuh money did it cost. I would like to do this if it is possible also my car is a 1995 firebird 3.8 thanks for any help
brakes
This topic is closed.
http://www.camarov6.com/cgi-bin/ulti...;f=23;t=002401
http://www.camarov6.com/cgi-bin/ulti...c;f=2;t=003418
http://www.camarov6.com/cgi-bin/ulti...c;f=2;t=002856
http://www.camarov6.com/cgi-bin/ulti...c;f=2;t=002069
http://www.camarov6.com/cgi-bin/ulti...c;f=2;t=001813
For more info, try a search in the Suspension forum. ;)Matt
1998 Mystic Teal Camaro M5
Not to be too overly redundant but my mechanic earlier was saying that if I swapped in a disc rear (a tooth chipped on my 3.42s) it's not just a bolt on swap, that I'd have to change the proportionary valve and master cylinder. Just checking to make sure I've read right that I do not need either of these. Thanks.97 Camaro<br />160* thermostat, z28 shock/springs, 3\" Magnaflow cat, 3\" Magnaflow catback, LT1 disc/limslip/3.42 rear, SLP CAI<br /> <a href=\"http://www.cardomain.com/memberpage/609893\" target=\"_blank\">http://www.cardomain.com/memberpage/609893</a>
Hey I talked to someone from Trans Am Creations
and they said it is a bolt on other than shorting the brake lines. I dunno other than I have herd some many diffrent things I think I will try it. after all the brake kit is only 150$ but i dont want to mess anything else up. if anyone else knows anyhting about this let me know thanks
The master is the same p/n and you have no proportionary valve. You have an ABS. Not only did I do this swap, but also put the LS1 brakes on the front. IT IS A BOLT-IN!!Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 days ago
