Stock V6 Shocks/Springs, 32MM front sway and stock rear sway? - FirebirdV6.com/CamaroV6.com Message Board
  • Stock V6 Shocks/Springs, 32MM front sway and stock rear sway?
    Would this be optimal to improve cornering and handling without excessive understeer or oversteer??
    C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail Birds
    hmm.. well according to the tech database you have a little softer springs than I do but bigger rear sway bar so I would guess you might be pushing it without stiffening up your springs some..
    so far I just have the 32mm on my car (1LE springs sitting in garage waiting on me to be able to afford bilsteins) and there is a transition point where you can tell the sway bar takes over for the spring.. and yes I have gotten sideways on dry pavement thanks to really pushing the car hard..
    anyway I would say you would proably want to upgrade to a stiffer spring just because yours are so soft.. and with the age of your springs I'm sure they are a little softer than they were when they were new..
    see you want a smooth transition as you push your car into a corner where the load is being transferred to the sway bar, if you have soft springs and a stiff sway bar that transition could be more sudden than you are expecting and make the rear end snap loose.. this would be bad..
    -Brad
    2000 V-Star Custom 1100
    :rock:
      I absolutely do not want to lower the car at all, so i'm out of options on the springs right?
        Why not get the z28 t/o shocks/springs and sway bars from SLP? Then you'll have the stock Z28 susupension with improved handling and road feel with an investment of about $120 - $150 (not 100% sure on price)
        BTW this lowers the car a very small amount like 1/4" i've been told...however most people say it is not noticeable..plus with the stiffer springs you don't bottom out as much.
        [ November 11, 2003: Message edited by: MississippiMaro ]</p>
        1993 Camaro 3.4L A4 many mods comin for 2004<br /><br />\"The last thing I wanted was to get in a fight in Jackson, Mississippi on a Saturday night\"
          yeah you can go with either regular V8 springs or 1LE springs these will not lower your car auctually should raise the nose a bit but not much..
          the suggestion of getting the v8 takeoffs is a cheap way for you to balance your suspension if you want to go with those big bars..
          -Brad
          :rock:
