I am going to install my Panhard that my girl got me for Valentines day. I was wondering if it matters how i do it, like does it matter if i put the car on jacks or on a lift or is it better if i just leave it on the ground? All i need to to is undo the bolts, take out the old one, slip in the new one, and redo the bolts right? No tricky business right?
Panhard install
It would be easier to do it with the axle off the ground. Jackstand the back up. that way if theres any movement, you can move the rear alot easier.
If its adjustable, you need to have it sitting on the tires with load on the rear.
But overall, no tricky buisness, very easy to do
Yeah mine is the non-adjustable 1LE, not like it comes in adjustable or anything. Cool, just making sure nothing silly happens.2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
So:
1) Jack up car (take weight off rear tires)
2) Remove old panhard bar
3) Install new (make sure you grease up). DO NOT tighten to specs just yet.
4) Lower car and tighten to specs.<a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
I backed my car onto Rhino Ramps and everything went fine - loaded rear end with plenty of room to work in.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...3 days ago
