Yet another 1LE front sway bar review - FirebirdV6.com/CamaroV6.com Message Board
  • Yet another 1LE front sway bar review
    Finally found a few hours to work on the car the other day, so I installed the 1LE (32mm) front sway bar I ordered a couple of weeks back ...
    Installed:
    SLP 1LE front sway bar ($76 + $20 shipping) from LM Performance)
    Polygraphite bar bushings ($25) and end links ($25) from PST
    Previous suspension/chassis mods:
    BMR shock tower brace
    Objective:
    Better-handling daily driver (no plans to hit the track ... wouldn't mind trying an auto-x one day though)
    The install:
    Took roughly 1 1/2 hours because I had a hell of a time getting the bushing bracket holes to line up properly, since the poly bushings don't crush like the rubber ones.
    Opinion:
    Well, it's certainly not a one-step fix-all for F-body suspension problems (not that I expected that), but it does eliminate a lot of body roll and quicken steering response.
    I've read several posts from people who think adding a bigger front bar without a larger rear will increase understeer, and some who say the increased camber control that comes with a bigger bar will actually result in a better balanced car. In the limited amount of driving I've done with the new bar bar on, I can't honestly say I've noticed either in "normal driving." (Yeah, it corners better due to the decreased body roll, but is it any more balanced?) What I do notice is that when quickly turning the wheel (like twisting between cones in a slalom test) the rear feels like it is on a slight delay and takes a sec to catch up. Maybe once I get the Bilstein HDs on, the better rebound will help that.
    Next up:
    Bilsteins, polygraphite bushings on the front "A" arms, rear lower control arms and panhard rod.
    2002 Firebird <br />Mods: Whisper CAI and Lid, K&N, Edelbrock Cat-Back, Hurst Billet Plus Shifter w/Lou\'s Short Stick, BMR STB, 32mm front sway bar w/polygraphite bushings and end links, PHB polygraphite bushings, HPP3 tuned
    Hows the vibrations? Did you get alot more? Thats what kind of turning me off from doing anything to my front suspension. As it is, I want to switch back to a stock tranny mount. :(
    95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
      No, haven't really noticed much in the way of extra vibrations or rougher ride. Seems pretty minimal. I'm sure that rubber tranny mount absorbs a lot of that.
