untill I get some wider tires. I will admit I am not the most knowledgeable person when it some to suspension setups, but this is what I have sitting in my room. H&R springs with KYB AGX shocks, along with a set of Spohn 32/22 sway bars. I am thinking the 22 bar will cause too much oversteer untill I can go with some 275's on 17X9's. I currently have 245's on the stock 16's. what do you guys think of putting everything on cept the 22 and wating till I get wider tires?
considering not using the new rear sway bar......
95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>Tags: None
i really dont think tire size is the best solution (the 345's should be fine). you might want to just look into a slightly smaller pair of sways.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
I think your setup is all wrong, I'll buy it for $200.
I'd either get a 19mm rear sway, or a 35mm front sway, I'd aim for the 35mm front sway.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
I think the 32 is fine for the front, the rear i think a 1LE would set you off just fine.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
alot of autocross guys run...
35/21 or 22
or
32/19
1LE is 32/21, I believe its a closer ratio do to the 1LE stiffer spring rate, I think they bumped up the ratings on the front springs alot.
Just my opinon though.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Or you could just consider doing it all and trying it out and seeing how you like it. May not be ideal, but maybe you enjoy a little more oversteer in your driving style but thats up to you.
If not you could always get a stock v8 19mm cheap, possibly free, until you save up and can get a 35mm front if you ever want to go to that.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
DO NOT use a 32/22 with 245/16 tires. You need at least the 275/17.
I had 32/21 with 275/17 and it oversteered slightly, changed to 245/16 for the winter and had "scary" oversteer. Now have a 35mm front and that is not enough. I'm going to a 19mm rear, and next fall will go back to the 275/17, but an all season tire rather than a summer tire.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
"I am thinking the 22 bar will cause too much oversteer untill I can go with some 275's on 17X9's"
"DO NOT use a 32/22 with 245/16 tires. You need at least the 275/17."
I don't understand (or believe) that tire size, if equal on all 4, will make a significant difference. You still have the bad behavior (oversteer) just at a faster and even harder to control speed.
"i really dont think tire size is the best solution ... you might want to just look into a slightly smaller pair of sways.
Bingo.
I just don't understand the fascination with big rear sway bars. The rear bar is a tuning device for your car, not a serious contributor to roll resistance. You need the _right_ size rear bar and 22 ain't it. It's like putting a full race cam on a stock motor, it just won't work. And the full race cam doesn't have the potential to send you spinning out of control, like a big rear bar does.
And, for the umpteenth time, 1LE is 32/19, not 32/21. GM tried 21s on a very few cars back when they first put out 1LEs as a competition only car, and dumped it fast - no doubt the racers said it was too big. 99+% of 1LEs came with 32/19. Saying a 21 rear is 1LE is just a marketing thing for guys who want to sell 21s and know they can't sell the easily available 19s.
[ February 24, 2005, 04:24 PM: Message edited by: V6Bob ]2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
Hey Andy, you have driven my car. It has 32/19 on 275 17x9.5 tires. How did it feel to you?
And don't say slow [img]graemlins/slap.gif[/img]New Toy Red 94 Formula LT1
RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
And don't say slow [img]graemlins/slap.gif[/img]95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
oh, I kinda forgot to mention, I ordered the sways thinking I would have the money to start auto cross'n this year. thats the big reasont he rear is so big. I had been considering getting a seciond set for street use but now that my transmission ****ed up a few weeks ago I no longer have the option for racing for a while so I am stuck with either 10 year old stock componets or what I have stated above. what about using the 32 with the stock rear? or would that cause way too much understeer?95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
If you need suspension help, talk to sam strano , he is very good with F-bodies. www.stranoparts.com . He won ESP autocross nat'ls twice I believe. He knows what he's talking about and knows the ins and outs of the f-body like no one I've talked to.2001 Pewder Firebird V6 A4 <br />Custom Turbo Kit Details On Site<br /> <a href=\"http://www.cardomain.com/id/njp98\" target=\"_blank\">http://www.cardomain.com/id/njp98</a> <br />Best 1/4 time NA - 15.224 seconds @ 87.55 MPH
http://tech.firebirdv6.com/1le.htmlRobert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by njp98:
If you need suspension help, talk to sam strano , he is very good with F-bodies. www.stranoparts.com . He won ESP autocross nat'ls twice I believe. He knows what he's talking about and knows the ins and outs of the f-body like no one I've talked to.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
on a side note... stock 15mm rear bar with 275s in the rear and LSD fecking blows [img]smile.gif[/img]-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
