My heady-ride Goes over a bump of pothole or even anything real small, and the steering wheel jerks a bit. its enough to make myself correct the wheel as i travel at speeds 40+. its really f-in annoying. whats with this? anyone have a simalir problem. Its worse than it sounds. what helps aborb the shock from the road? [img]graemlins/rant.gif[/img]
Hitting bumps- action transfers to the wheel
Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.Tags: None
Does it do it on both tires?
Are you hitting the bumps with the tire that jerks? or are both tires hitting the bump?
When did it start and did you have any front end work done during this time?Patrick<br />Sick Sixx Member<br /><b>97 Mystic Teal Camaro</b><br />425RWHP @14PSI<br />Old setup:<br />330RWHP @7PSI 13.9 @ 106.6 <a href=\"http://www.fullthrottlev6.com/forums/vbgarage.php?do=view&id=4\" target=\"_blank\">Mods</a>
Sounds like bumpsteer. Your tie rods could be worn out. I had real bad bumpsteer and had to get some adjustable tie rods from Baer. They were kind of a pain to get adjusted right....took 5 shops to finally find one to do it.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
it does it with both tires. the rear doesn't handel well either. i know the car it not a porse but what does your cars handel like in rough terrain?Heady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 days ago
