Does anyone happen to know the length of the stock spacer sleeve on the 98-02 rear 15mm swaybar endlinks? Any help with this would be greatly appreciated.
Endlink question
I also need to know if anyone knows the energy suspension part # or just the length of the stock rear swaybar endlinks. I found out last weekend that mine are bent to hell for some reason :I-Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
Serpint: go one better. I see you have lowering springs, so just get custom endlinks that the sway bar ends will be perpindicular to when the car is loaded.
Stock endlinks on a lowered car cause the sway bar to be tilted relative to the endlinks, which loads the bushings somewhat. This can cause faster bushing wear at least.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
thats why i am going with energy suspension. when i did the shocks/springs initially, the front swaybar endlings were rusted so bad that they broke off at the bolt heads when we tried to unmount them to make the install simpler. we replaced them with some energy suspension parts and the fronts have given me no problems in the last year, so i figured i would go with them again.-Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
2-5/16" is the length of the spacer as supplied with the 1LE sway bar kit I just received.180 Thermo, K&N Filter, Transgo stage 2, Pacesetters, Magnaflow cat, Flowmaster Catback, 3.42 LSD, Hotchkis LCA/Panhard, Bilstein, Eibach Pro, 1LE bars, SP crossdrilled/slotted rotors.<br /><br />Vortech Project 1.0 failed.<br />Vortech Project 2.0 in the works
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...18 hours ago
