Ur cars do not act like a caddy. of course u are going to feel every bump and stuff, i sure do. it will be impossible to not feel the road your driving on, our cars are low to the ground and dont aborbe shocks very well , as to a caddy. but if your going to upgrade eveything it should help some, but not totally eliminate it.
How Can I Obtain A More Quiet Ride ????
You bought new ultra high performance summer tires, in a wider size (less sidewall) and your ride (and maybe road noise too) is worse. No surprise, choosing tires is a tradeoff and the new tires are almost surely the reason for your stiff ride.
To answer your question, these would make your car much smoother and quieter, but won't handle as well. 215/60s would give you the best ride/least noise.
http://www.tirerack.com/tires/tires....nce+ComforTred
Shocks and ride is a complicated thing. Performance shocks, like Bilsteins, will generally be a bit stiffer, but will control bumps more precisely. For some that translates to a better ride, for some, worse. Matter of taste. Sam Strano would be a good source for ideas on shocks.
[ March 07, 2005, 04:14 PM: Message edited by: V6Bob ]2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
Well, I checked the air pressure on the tires today and for my surprise they were a mess. The right front tire had 45 psi, the left front tire had 36 psi, the right rear tire had 40 psi and the left rear tire had 38 psi. I was f*ing piss off. I'am calling those guys tomorrow (America's tires).
Anyway, I set them all at 35 psi and the ride is unbelievable better. Like day and night. I chose 35 psi because I thought that would be good but if I am wrong please correct me. Still, the ride is much better now.
Like I said on my first post, our cars don't have the most confortable ride, and I knew that, but the ride got worse after I put the new tires. I didn't know if it was the tires or my shocks (that I still believe are bad. Any way to checkt that?) but now I know it was definetely the tires.
Thanks for your help guys.
[ March 08, 2005, 02:35 AM: Message edited by: Georghino ]2002 Arctic White Firebird W68<br />Installed: FTRA, Carbon Fiber Whisper Lid, K&N Filter, Transgo Shift Kit, Corvette Servo, 160º Thermostat.<br />Appearance: Potenzas RE750 245\'s, 3M Tint 20% All Around, Clear Corners.<br />FOR SALE: HPP3
