im gettin those hot z06 rims 17 with the 275/40 tires....are those gonna fit with no problem in all 4 wheel wells??/
275/40 17s fit w/o modif?
This topic is closed.
they are replicas....so i should be straight then, hell yea....time to get the check book outSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
The only thing you may have a problem with is the rear tires rubbing inside of the wheelwell when you hit a bump. This can be caused by worn out springs. You can easily fix it by installing a jounce bumper spacer like I did, or install new'er (less worn) rear springs...or both ;)
Congrats on the buy, and post pics when avail.
-Marcsigpic
Yeah as everyone else has said you wont have a problem. I have the Dayton 275/40 ZR 17 on Firehawk rims and they are great. The only con that I have is that you feel alot more driving than you did with the stock tires.
Good luck man.
Travis1995 Firebird 3.4 V6 M5<br />-Firehawk 17x9 w/275/40/ZR17, flowmaster 80s, high-flow cat<br />*new* BMR lowering springs, Bilstein shocks, WS.6 sway bars, polyurethane bushings.
Good luck man.
