I already put lowering springs, shocks, and wider rims/tires on my car to improve its handling. Now I would like to finish the basic suspension upgrades by adding front/rear swaybars and a strut tower brace. My question is what sizes should I get for a street application. I probably wont be autocrossing, and I will occasionally drag race if that makes any difference. Also where would be the best (cheapest) place to find good quality parts that will make a noticable difference? Thanks.
Swaybars and strut tower brace
Search....swaybars has been discussed a lot. If you have replaced springs and shocks the 1LE swaybars will probably work for you. Thats what I have and I have upgraded my entire suspension minus A-arms. You may want to get some LCAs' and an adjustable panhard bar so that you can adjust your rear end....lowering your car will cause it to shift right a little. These will help with wheel hop and your cornering ability.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
Either a 32/21 or 32/19 GM bar setup should be plenty with HDs and lowering springs.2002 5-spd NBM Camaro
Details: www.1lev6.com
Sub frame connectors will stiffen you up a little too so look into a set of those.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
BMR has nice sway bars for a reasonable price. My boyfriend has them on his 99 Z and they work nicely. Also, as someone else said, Sub Frames would make a nice improvement on stiffening up the car. They make a huge difference in my opinion.
Later,
Erica2002 Navy Blue Camaro<br />Tinted Windows, Chrome Rims, West Wings Grill, Flowmaster Cat-Back.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
