I already put lowering springs, shocks, and wider rims/tires on my car to improve its handling. Now I would like to finish the basic suspension upgrades by adding front/rear swaybars and a strut tower brace. My question is what sizes should I get for a street application. I probably wont be autocrossing, and I will occasionally drag race if that makes any difference. Also where would be the best (cheapest) place to find good quality parts that will make a noticable difference? Thanks.
Swaybars and strut tower brace
Search....swaybars has been discussed a lot. If you have replaced springs and shocks the 1LE swaybars will probably work for you. Thats what I have and I have upgraded my entire suspension minus A-arms. You may want to get some LCAs' and an adjustable panhard bar so that you can adjust your rear end....lowering your car will cause it to shift right a little. These will help with wheel hop and your cornering ability.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
Either a 32/21 or 32/19 GM bar setup should be plenty with HDs and lowering springs.2002 5-spd NBM Camaro
Details: www.1lev6.com
Sub frame connectors will stiffen you up a little too so look into a set of those.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
BMR has nice sway bars for a reasonable price. My boyfriend has them on his 99 Z and they work nicely. Also, as someone else said, Sub Frames would make a nice improvement on stiffening up the car. They make a huge difference in my opinion.
Later,
Erica2002 Navy Blue Camaro<br />Tinted Windows, Chrome Rims, West Wings Grill, Flowmaster Cat-Back.
