ok im getting the z06 rims from discount tire direct. they say i should get the wheel installation kit which includes the ug nuts and such plus they say i should get the valve stem, i dont even know what that is.....should i just get those two things when i get the wheels?
getting rims - few questions
The valve stem is what allows you to put air in your tires. They make a couple different kinds. You can get your standard black rubber ones that pop in the rim or you can get the metal stems (some are chrome plated) which use a small nut with rubber washers to hold it in the rim. Both do the same exact thing, its just an apearance thing.
How much is the "kit?" If it's not too much I'd prob get it because you'll need that stuff anyway.2006 Tiburon
