I can either get the lakewoods for 115+ shipping or I can get the both 1les for 120+shipping. My stock ones are broken and I might as well upgrade. I dont want expensive ones. I dont want any extreme vibrations either. What do u guys recomend.
lower control arms?
I just found lakewoods for 90 bucks at jegs so I think i am getting those. Is that a good choice?1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
1995 Camaro 3.4L Black with T tops, 5 speed manual<br /><br />Mods:<br />Pro 5.0 short throw shifter, MSD Ignition coils, 3.73 gears, Torsen LSD,Mac diff cover, Umi LCAs<br />K&N Cold Air Intake, Window Tint (20% rear, 35%front), aluminum driveshaft, fastchip tuning
spohn
BMR
UMI
Tubular LCA's are the way to go. The lakewoods are cheep for a reason.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
is that your advisable order? no
why not get boxed? seems stronger, plus i aint dropping mine (stock)2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
unless your running 10's or better (in the 1/4) boxed is severe overkill. The added weight is bad. Tubular will work just fine. I have BMR chrome moly adjustable LCA's and they are great. However I got adjustable because i have a 12 bolt and needed to re center the wheels in the body. You don't so just a normal Poly bushing, tubular LCA will work great. Thats the order that I like. I feel spohn is just slightly better then BMR, and I like UMI but don't have any hands on with thier products.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
Why? your never going to break tubular. Why add more weight when tubular will do fine. Chrome moly is even better because it's stronger while weighing less. Even on BMR's site they say that boxed is overkill. You being too cheep to buy chrome moly is not a good argument for suporting boxed.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
well i searched and many people say the lakewoods are awesome. Also many people have told me to stay away from tubular. Now im confused so which is better.1995 3.4L M5 Camaro<br />Bullet Performance Exhaust, K&N FIPK, Stage 1 clutch, Short shifter, Hotchkis STB, Taylor Ignition wires, NGK spark plugs
you have 2 choices. Tubular or boxed. Both will work. Tubular is lighter and smaller. Boxed is heavier and larger. Neither one will ever break on on. Maybe people (V8 people) have broken the lakewoods. For this reason, stay away. no V8 should be breaking a LCA.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
listen to the man preach
he tells it how it is
my car still doesnt deserve chrome moly tho
lol
i wonder if the tubular would bend/flex when pushing the limits to where you would rather need boxed.
go w/ tubular2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
tubular is never going to bend or flex on you.1996 Silver camaro Z28. M6,<br />12 bolt, 4.11\'s, posi, Rear cover, Spec stage 2, loudmouth, more <a href=\"http://home.mainstreamtopics.com/?index=3&module=1\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=1</a> <Mods, Pics & more <a href=\"http://home.mainstreamtopics.com/?index=3&module=2\" target=\"_blank\">http://home.mainstreamtopics.com/?index=3&module=2</a> <Fbody Tech Articals
box = track only really
Tube = street (for the cruves) and track they work fine
the box one's don't flex as much and under hard cornering it does not plant the rear tires as well
check out www.ftpp.net they carry about everykind for our cars.www.turbov6camaro.com
1997 3800 Series II Camaro
