suspension performance - FirebirdV6.com/CamaroV6.com Message Board
  • suspension performance
    Alright here the suspension well my goal for having the v6 right now
    UMI A arm Kit
    UMI QA1 Generation f "R" series coil over kit (Drag Racing)
    QA1 Generation Single Adjustable shock rear
    SLP 21mm Rear 1le sway bar
    BMR 32mm front sway Bar
    BMR Adjustable torque arm
    BMR rear springs only lower
    In the future I was going to get this but have some questions
    UMI Shock tower brack chrom moly
    BMR K-Member Km003 or 3-1 (I dont know which one?) help me out
    UMI subframe connectors
    So what do you guys think? i am going all out on the suspension so let me know what you guys think?
    2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
    yes, if ya want drag
    then definately start with tweaking the suspension
      My goal is a good performance car good on streets but able to adjust it for drag has well
        if your not going to do autox, why do sway bars?
        WAWA-A-HOLIC
          No, No, No!
          Raven
            Originally posted by FirebirdGT:
            </font><blockquote>quote:</font><hr />Originally posted by Bankz27:
            No, No, No! </font>[/QUOTE]when you upgrade the entire rest of the suspension, when is a bigger rear bar OK? like the hotchkiss or Eibach rear bars.... I would assume that they designed them to be used with their springs, no?
            \'01 Mineral Grey SVT Cobra<br />-former F-body owner
              "when you upgrade the entire rest of the suspension, when is a bigger rear bar OK? like the hotchkiss or Eibach rear bars.... I would assume that they designed them to be used with their springs, no?"
              One would hope so, but I'd want to talk to an engineer at the company (not the retailer) and confirm that.
              Frankly, the only people on the Net that seem to know what they're doing and use 21mm rear bars have monstrous roadrace front springs, like 600s. I've never seen anyone convincing using a 25 rear.
              On rear bars it is better to go a little small than a little large. Especially for the street. Even on the track, a serious competitive racer would swap in a smaller rear bar if they knew the track was going to be wet.
                Your missing some basics components there.
                A-arms are good, and the coil-over kit is good, but you need goos front struts too, The torque arm isn't necessary with your car, save that money and get panhard rod and lca's.
                Why would you get lowering springs for just the rear? thats stupid, i could see the front, but not jsut the rear.
                Subframes are a plus, the k-emember is not needed, and the shock tower u can use mnild steel and ssave yourself some money
