BMR Strut Tower Bar? - FirebirdV6.com/CamaroV6.com Message Board
  • BMR Strut Tower Bar?
    What exaclty are these good for?
    <a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
    Looks pretty under your hood. You'll be better off with SFC if you want a stiffer chassis.
      An STB keeps the front chassis from bending inwards during turns and otherwise flexing when going over bumps - I really enjoy mine and noticed a big difference after installing mine. Great investment for just $90, the install is easy sneezy.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        Will it fit my 95 3.4 auto?
          Yes, it will fit.
          You should get the subframe connectors too like Dom suggested. Especially since you have a convertable. Big difference.
          - JT3<br />1998 Red V6 Camaro Y87 Y3F - J.E.T. Chip Stage II - Clear Parking Lights - Removed Grill - K&N - Whisper Lid - !FRA MOD - MAF Screen Removed - Pro 5.0 - Pacesetter Headers - Magnaflow Catback - 32mm Front Swaybar - And A System(bump bump)
            here is the info that i've come upon while looking into these things (i've been wanting to get one myself, but since I have a Coupe (no t-tops, or convertible top), i've decided against going with any of these things for now.
            If you have a convertible or a t-top car, subframes will make the ride better and the strut bar will tighten up the front end a lot making for better turning control, etc.
            if you don't have t-tops, just replace the shocks and that'll make the most noticeable difference other than doing the subframe and strut tower brace solution.
            just my 2¢
              The best way to describe what the STB did for my car is this.You know how when you take a hard corner the opposite side of the car tends to "dip" down toward the road?The STB takes care of that.The car just turns and goes now,there is no more "dipping".The sub-frames helped stiffen the car even more.
              Kevin
              1998 Black Z28<br />1995 Black 3.4 (@#$$%* ex took it!)<br /><a href=\"http://photos.yahoo.com/bc/nikkev1/lst?.dir=/New+Camaro&.view=t\" target=\"_blank\">Pics</a><br /><a href=\"http://www.scfyb.com/phpBB2/\" target=\"_blank\">Carolina Board</a>
                Yeah, subframe connectors are probably the best bang for the buck suspension mod you can do. GM should've included them on the coupes anyway (some weak ones already come on the conv). I have BMR weld-in SFCs, and the difference is night and day. The whole chassis feels 10X stiffer, and the suspension can do its job more effectively. The STB is okay, but our cars don't need it nearly as much as SFCs.
                Edward D.<br />1997 Firebird A4 - Black Metallic<br />SLP CAI, Decoma 3\" Catback<br />BMR SFCs, 1LE sway bars<br />some other stuff
                  Get the STB. You won't regret it. Well worth the money. Front suspension is so much better with it. Minimizes high speed cowl shake, car more responsive in turns. Well worth the money. I have a hard top so I didn't need the SFCs, but they're right about them. Even if you go with the SFCs, I would still get the STB. They address two different areas in my opinion.
                  <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
                    My Hptuners stop working
                    Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...
                    13 hours ago
                  • Money pit
                    Zzp cams
                    by Money pit
                    Has anyone used zzp gt1 cam if so is it worth the money and time
                    2 days ago
                  • thatpewterfirebird
                    2001 3800 s2 firebird
                    by thatpewterfirebird
                    4 days ago
                  • Turbo 3800 camaro
                    Where are the videos?
                    by Turbo 3800 camaro
                    6 days ago
                    New Chevele
                    Just saw it on Facebook, looks awesome. The front and rear nice looking....
