Spring Cutting - FirebirdV6.com/CamaroV6.com Message Board
Spring Cutting
  • #16
    The springs in our cars do not twist at all under compression. A spring that is rated at 300# will be 300# no matter how much you cut our of it, and will compress 1 inch for every 300 pounds that is added to it. The formula is y=kx, where k is the spring constant. So if you cut a coil out of your springs, it is still going to have the same spring constant, it will still COMPRESS the same amount, you will just bottom out at a lighter FORCE. NO TWISTING
    1995 Firebird 3.8 A4, 140,000 miles and going strong<br />Basically Stock, college=poor <p>Junior Mechanical Engineering Student: Milwaukee School of Engineering; Cpl, MN Army National Guard...just got promoted :)
    • #17
      Sigh. Ok, you sucked me in (musta been the capital letters). The problem with your formula is that k, the "spring constant" is only constant for a particular spring. It is not constant if you cut coils out. The equation for a coil spring is:
      k = [1,500,000 X d(to the fourth power)] divided by [n X D(cubed)]
      d is the diameter of the spring wire, n is the number of coils, D is the diameter of the coils. Decrease n and k goes up accordingly.
      This web site spells it all out:
      http://www.teammatrix.com.my/CarMods/potongspring.html
      This web site has the formula and is also a spring constant calculator.
      http://www.kaila.net/tl125/spring.html
      And the spring wire does twist :D .
      2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
      • #18
        how many times do we have to say it..i rode in the car numerous times before the cut and i rode in it after and there is no difference at all..NONE
        dont be so closed minded to think that cutting 1 coil i going to make your car ride like azz
        [img]smile.gif[/img]
        • Manimal
          Coil springs
          by Manimal
          6 days ago
        • Manimal
          Newby here
          by Manimal
