The springs in our cars do not twist at all under compression. A spring that is rated at 300# will be 300# no matter how much you cut our of it, and will compress 1 inch for every 300 pounds that is added to it. The formula is y=kx, where k is the spring constant. So if you cut a coil out of your springs, it is still going to have the same spring constant, it will still COMPRESS the same amount, you will just bottom out at a lighter FORCE. NO TWISTING
Spring Cutting
Sigh. Ok, you sucked me in (musta been the capital letters). The problem with your formula is that k, the "spring constant" is only constant for a particular spring. It is not constant if you cut coils out. The equation for a coil spring is:
k = [1,500,000 X d(to the fourth power)] divided by [n X D(cubed)]
d is the diameter of the spring wire, n is the number of coils, D is the diameter of the coils. Decrease n and k goes up accordingly.
This web site spells it all out:
http://www.teammatrix.com.my/CarMods/potongspring.html
This web site has the formula and is also a spring constant calculator.
http://www.kaila.net/tl125/spring.html
And the spring wire does twist :D .2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
