i did a search but didnt relly find the answer i was look for. my rotors are warped (oem's) what would be a good replacement set for them, aftermarket blanks, cross drilled, slotted, or both
rotors
yeah i would stay away from slotted and drilled rotors, especially because drilled rotors are crack prone.
not only that but for the kind of braking we do, the fact that the rotors are drilled means they have less surface area... thus the brake calipers have to work harder to acheive stock performance. the "ventilation" effect is NOT worth it on a daily driver.
porsche and ferrari competition cars are a different story, but so are the manufacturing standards for their brakes.
Originally posted by blackbyrd:
k im confused wich ones shoud i get
-Marcsigpic
I use slotted rotors, but I also use my car for auto-x. Having fresh contact areas is kind of critical when you are having to do 35->0, 45->0, and 55-> repeatedly and your brake pads and rotors are hot enough to vaporize water.
Reminds me, I need to get new brake pads all around and new rear rotors too...-Mark (aim: Eredasx)-<br />Black 01 Bird. 3\" exhaust. Eibach pros. Tokico shocks. Whisper lid. SLP CAI. LS1 DS. SLP fan switch. LSD. BMR PHR, LCAs and STB. Status: still repairing damage from punk thieves.
I just installed a set of crossdrilled and slotted SP Rotors with Hawk pads. Aside from a little noise during break-in, I think these are a fantastic upgrade from stock. The machining is excellent and there aren't a million holes in like some other brands. Stopping power is much improved and they look really cool.180 Thermo, K&N Filter, Transgo stage 2, Pacesetters, Magnaflow cat, Flowmaster Catback, 3.42 LSD, Hotchkis LCA/Panhard, Bilstein, Eibach Pro, 1LE bars, SP crossdrilled/slotted rotors.<br /><br />Vortech Project 1.0 failed.<br />Vortech Project 2.0 in the works
Cross Drilled rotors will only crack if you are racing your car and slamming on the brakes from light to light. For normal every day driving they will be fine, just break them in properly. If you are VERY hard on brakes, go with the slotted rotors..
I have the KVR cross drilled rotors and KVR Carbon Fiber pads, I can stop just fine.<b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
If your worried about cracking go for the slotted and dimpled rotors. Aftermarket does make a big improvement.95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 hours ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....4 days ago
