Hi im new here,but not to cars my 96 firebird has a very bad rattle from the rear end its from 0-to about 45-50 then its gone a friend of mine has the same trouble from his 91 RS he thinks its his rear dif im not so sure ive goten under my rear and checked all moving parts nothing im sure its fairly common so any info will help....thanks!!
rear rattle! help!!!
perhaps it could be the rear backing plate for the emergency brake rotor. that's what's wrong with my car right now. GM has a service order for those, maybe this might help you out.
GM service order: #01-05-23-010 (Sept. 21, 2001).
It's for 2001-2002 Camaros and 2001-2002 Firebirds
I'm sure with the search button, you can find more info about it.99 Camaro RS - 3.8L V6<br /><br />Modifications<br />Exhaust: Magnaflow OBD-II High-flow Catalytic converter / Magnaflow catback exhaust<br />Intake: Shaved Airlid / 3\" PVC tub<br />Suspension: V8 springs / DeCarbon shocks / 32mm 1LE swaybar / 19mm rear swaybar
I KNOW I’m gonna get laughed at for this, but…
When I first got my car (97 RS), I had a “tapping” rattle that I couldn’t find. I thought it was the exhaust or something, but for the life of me, I could never find it.
After several weeks of complaining to my friends, I finally found it.
It ended up being the latch on the back seats. I wrapped the left bar with some medical tape, and no more rattle. Sigh...
[img]graemlins/slap.gif[/img]1997 Camaro RS<br />Home Brew CAI
I had the same problem when i first bought my bird. Couldnt figure out what it was until i had my car lifted up in the air and the front stabilizer bar link was broken off it rattled like crazy. Replaced it dropped the car down took it for a spin still rattled. Put it back up in the air looked and rear stabilizer link was broken as well fixed it rattle went bye bye might wanna check that out man.John<br />Flowmaster custom piping, K&N intake and filter, catco high clow cat, stage II clutch, More to come.<br /> <a href=\"http://www.cardomain.com/ride/2036060\" target=\"_blank\">http://www.cardomain.com/ride/2036060</a>
Could be spare tire / jack. Wasn't on mine, but it's worked for others. Tighten it down, or drive around the block without it and see if it still does it.2000 M5 Pewter Firebird [Monsoon stereo]<br /><a href=\"http://www.centerlinewheels.com/sub_wheel.php?mw_id=2\" target=\"_blank\">16\" Centerline Galaxy Wheels</a> . <a href=\"http://www.bfranker.badz28.com/headlightfix/\" target=\"_blank\">Headlight fix</a> . Under dash lighting . Dashmat . Headlight conversion<br />84k miles<br /><br /><a href=\"http://www.cardomain.com/id/tucsonbird\" target=\"_blank\">Cardomain</a><br />Tucson, AZ
