removing rear springs, only - FirebirdV6.com/CamaroV6.com Message Board
  • removing rear springs, only
    whats a quick step by step for removing rear springs only, leaving the shocks on?
    thanks
    ian
    97 camaro<br />black, 5 speed, t-tops, rockford fosgate cd w/4X6.5\" rockford speakers, 3\" flowmaster american thunder catback with 3\" carsound cat, SLP CAI, B&M Ripper w/leather Hurst shift knob, 5% tint.<br /> <a href=\"http://camaroz28.cardomain.com/id/ianwells100\" target=\"_blank\">http://camaroz28.cardomain.com/id/ianwells100</a>
    Not gonna happen without use of explosives. It's only one fastener at the bottom of each shock.
    180 Thermo, K&N Filter, Transgo stage 2, Pacesetters, Magnaflow cat, Flowmaster Catback, 3.42 LSD, Hotchkis LCA/Panhard, Bilstein, Eibach Pro, 1LE bars, SP crossdrilled/slotted rotors.<br /><br />Vortech Project 1.0 failed.<br />Vortech Project 2.0 in the works
      cool, thanks... i just wasnt sure, cuz i know they're not the same as the fronts
      thanks for the help [img]smile.gif[/img]
        Actually it is very possible without loosening the shocks. But if its your first time, then just put the car on jackstands on the body, letting the rear end hang free. Put a jack back under the diffy to support it and take up some slack. Remove the shock bolt on the diff and then let the diffy come down slowly using the jack. The springs will basically fall out. Not difficult at all.
        Cp
          Cp
            :eek: holy double posts batman :eek:
            2002 Firebird<br />2003 Yamaha YZF 600R
              [img]graemlins/rofl.gif[/img]
              2000 3.8 A4 Pewter Camaro
                Rear springs can be removed and new ones put installed within 7 minutes and 49 seconds. Our record :D
                  Thats only after the frustration of working on a set of shocks for 6+ hours
                  Shawn<br />2002 Silver W68 Firebird
                    yyeeeeeaaaaaaahhhhhhh [img]graemlins/rock.gif[/img]
                      The shocks do not have to come all of the way out, obviously. Just take the nut off of the bottom of the rear shocks and free them from the axle. Then, when you lower the axle, you can remove the springs.
