homemade linelock? - FirebirdV6.com/CamaroV6.com Message Board
homemade linelock?
  • homemade linelock?
    anyone ever made their own linelock? the hurst one is kinda expensive.
    --matt
    its like $120 isnt it? thats not bad at all for an electronic line-lock kit
      yah, $125. i'm just wondering if anyone else has found a cheaper alternative. anyone know where i can get just the actuator?
      --matt
        I highly recommend the SLP unit.
        1997 Dodge Viper GTS
          JC Whitney sells a line lock I believe. (not 100%)
            I have heard good things about the slp one, but not sure how much it costs...
            as for making your own linelock?
            I woudl be iffy... thats one of those things where if you have an unforeseen problem, "whoops" can be dangerous.
              $139 for the SLP Unit.
              It goes on EASILY and looks factory.
              I am sure it meets or exceedes factory quality, which is very important, especially for brakes.
              It comes with all pre-bent metal brake lines that look exactly like the factory ones.
                this is true all the ones I saw in person looked like they were almost factory.
                  Back on topic, you can just get a solenoid.
                  like this
                  But by the time you buy the lines and hardware, it will cost you about the same, and you will have the awesome "Rigged" feeling... :(
                    $120 something for the SLP unit from LMPerformance.
                    I love mine - it's slick and easy. Shop said it was a breese to install. (I'd have done it myself, 'cept brake lines is something I'd rather not mess with.)
                    OFFICIAL TROLL
                      Yeah if you don't own line wrenchs, don't touch the brake lines.
                      I was a breeze ton install, once I found the line wrenches... (brake line nuts were TIGHT and try to strip out!)
                        I got the SJ Manufacturing one for $115 shipped. [img]smile.gif[/img] The model I purchased uses the Biondo soleniod, other more expensive models use the Hurst, others.
                          have a link?
                          like this
                          problem with that one is it's only good for one line,,,i got the '02 camaro with abs so therefore i have two lines going to the front brakes....ditto with the tci one. so i think i'm stuck geting a slp or hurst solenoid..
                          thanks guys for all the info!
                          --matt
