Where might I find a new/reproduction or NOS jumper harness that plugs into the front wheel ABS sensors? Car is a 03 Camaro V6 auto. Location: Garden City, NY
Front wheel ABS sensor jumper harness replacement?
I think you mean 2002, ebay, or a scrap yard. What makes you think its the harness and not the sensor?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
They have them at Rockauto too, $20 A/C Delco.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Did you loose any of you mounting points for the ABS wiring, I know in about 2005, some of my tabs holding my abs line broke and it caused the abs to come on, just zipped tied them real good and never had that problem again.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411 View PostDid you loose any of you mounting points for the ABS wiring, I know in about 2005, some of my tabs holding my abs line broke and it caused the abs to come on, just zipped tied them real good and never had that problem again.
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 weeks ago
