Can the RS and SS use the same suspension
Suspension
Definitely need to know the year in question. For the 5th gens if I remember correctly the V6 struts are a little taller than the SS ones for example.
Everything I have read says that the SS suspension will fit the v6 and many do do the swap.
What you will find is:- Your car will have the same stance as an SS
- Your V6 Camaro will lower about 0.5”
- The springs are a slightly stiffer spring rate, so the handling will have less roll and be improved
- You will want to get SS shocks as well as they also are a little stiffer and I also believe a little shorter.
- 1 like
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...4 weeks ago
