Do 6th Gen Brakes fit on 5th Gen Camaro? - FirebirdV6.com/CamaroV6.com Message Board
  • Do 6th Gen Brakes fit on 5th Gen Camaro?
    Does anyone know if the brakes from a 6th gen Camaro fit on a 5th gen Camaro at all?
    No they do not. The lugs are bigger and the hat on the front is different across those generations.
    I also believe that the rear has a different offset as well. If you are looking to upgrade your 5th gen Camaro brakes you will need to stick with aftermarket setups.
      Still trying to find oil leak
      2 days ago
      Getting some work done on my truck
