Is this for your 98’? I don’t see the point unless your rubbing. I use spacers on my ZR1 17 x 11 rims for the rear when I put them on. Only because they rub without spacers. The spacers you posted look good though.
I have the 15mm Eibach p/n 90.6.15.033.1 in the rear (these ONLY fit 97+ axles) - you will need to install longer wheels studs - such as Dorman p/n 610-323
Do your rims rub Robert? I remember you have the C5 front brake kit, do you need them for that?
Yes - I have C5 calipers in the front - but not "the brake kit" as I don't have C5 13" rotors.
Oh, okay
Here’s mine Edgar, big ones are for the rear, 1” spacers for the 17”x11” ZR1s, the smaller are universal 1/4” spacers for the front 15”x6” PRO stars, can’t use them now because went to 98+ brakes.
Has anyone used zzp gt1 cam if so is it worth the money and time
