Abs inop - FirebirdV6.com/CamaroV6.com Message Board
Abs inop
  • Abs inop
    Hello, so I changed the front bearings on the bird and the ABS inoperative light came on. I made a mistake of not removing negative battery cable. Now do I turn this off. I tried removing both cables from the battery and it didn't work. Would a regular scanner work?
    Are the abs wires all secure ?
      I believe so. I think there's only one that I unplugged.
        I just cycle it turn the key to the on position but don’t start it until the full pump primes then start. If it is still on then you have a sensor out or one of the wires is not secure. You only did one wheel bearing? Usually I’ll do both at the same time.
          I still have trouble with mine, every other start the ABS light comes on, I’ve done the wheel bearings and the sensor on the rear differential. So I just live with it.
            Just one. I'll double check again this weekend. Thanks Steve.
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
              1 day ago
            • fishin
              by fishin
              3 days ago
              Had to be evacuated again due to fire
