stock tire hight - FirebirdV6.com/CamaroV6.com Message Board
stock tire hight
  • stock tire hight
    i just want to know what is the stock tire hight i have 235/55/16?
    2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
    Re: stock tire hight
    look on the inside of your door, its there
      i checked and there was nothing
        Are you looking for the stock tire size that should have come with your car, or are you looking for the actual measurements of your 235/55/16?
        You can visit 1010tires.com and use their tire calculator to determine all the measurements of your tire. Here's what I get when I plug in your tire size:
        Overall diameter: 26.17"
        Sidewall height: 5.08"
          actual measurements of my 235/55/16 from the ground up so its 26.17" ?
            26.1 off of tirerack.com
              cool thanks guys :)
                I got 26.2" from my unit conversion in hp tuners.
                <a href=\"http://www.fbodyelpaso.org\" target=\"_blank\">www.fbodyelpaso.org</a> A4 stock 3.42 and LSD not Y87,SLP cold air induction, whisper lid, k&n filter, flowmaster 80 series, hypertech, 160 powerstat thermostat, t/a front bumper, functional nostrils, pacesetter headers best et: 15.9 at about 4800ft
                  The formula is:
                  Take the first number, divide by 25.4 (converts mm to inches)
                  Take the second number, divide by 100 (converts percentage to fraction).
                  Multiply them together, gets sidewall height. Multiply by 2 because you have 2 sidewalls.
                  Add the last number (wheel size).
                  That gets you 26.2. That's good to within a couple of tenths, because manufacturers don't make the size exact. The way to get the exact size for a new tire is to get the manufacturers specification.
                  Of course, as a tire wears out it will become about half an inch shorter.
                  2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
                    cool thanks reason i ask for tire hight is cuse i had 3.42 and now got 3.73 for a while and my speedo and shift points are off hpp3 only goes up to 3.42 doesnt have the opions to go up to 3.73 and higher so i heard that if u change the tire hight with hpp3 u can correct your speedo and shift points now im just try to figure out the right hight to do this if anyone out there could give me some poiters that would be greatful
                      Here's the method. A 3.73 will make your wheels spin faster at a given speed. A shorter tire will do the same thing. You need to use 3.42 and 3.73 to come up with a shorter height. The only reasonable way to do that is:
                      multiply 26.2 by 3.42 and divide by 3.73.
                        hmmm i though u had to raise the tire height to make the speedo and shift point to work right never heard of it going down but ill give it a try i did the math and it came out to be 24.02252 so do i change the height 24?
                          anyone????
                            If you can "trick" HP Tuners that way, enter 28.55" as your tire height and see what happens. It might be that programming for 3.73 doesn't exist in the stock cal so, obviously, the Power Programmer can select it. Hopefully, the Power Programmer will support tires that tall.
                            Please report back to the list on your results. I'd be interested to read them.
                              Me too. I think you have it backwards. A "shorter" gear like 3.73 acts like a _smaller_ tire.
                              In both cases the engine has to spin more revs to move the car the same distance.
                              http://www.carcraft.com/techarticles/1007/
