i have a shot at some Z28 springs off of a 94, are these a vast improvement over my 98's springs, i may also have a shot at the ones he replaced them with.
z28 springs
Re: z28 springs
I would say no. the rears will be the same. the fronts will be almost no diffrence. only diffrence will be it will sit higher because it dosen't have the weight of a V8 on the front.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
Re: z28 springs
Front:
22133438 (45 N/mm, 257 lbs/in) (98-00 V6)
22077197 (51 N/mm, 292 lbs/in) (93-00 V8)
Its definitly stiffer but not by that much.1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
Re: z28 springs
Originally posted by andrew.brandononly diffrence will be it will sit higher because it dosen't have the weight of a V8 on the front.
Curb Weight - Automatic (lb.) (V6) 3525 (V8) 3613
Curb Weight - Manual (lb.)............3479........3591
wow, the whopping 100 lbs of a v8, a passenger weighs more
but anyways, will it be a noticeable improvement, and yes i do have bilstein HDs on the way
Re: z28 springs
Originally posted by bahthis always makes me mad when people say this, i've quoted this before
but anyways, will it be a noticeable improvement, and yes i do have bilstein HDs on the way2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
