1LE vs Aftermarket Sway bar "front" - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: 1LE vs Aftermarket Sway bar "front"
    Originally posted by Hib Halverson
    You seem to know spring rate information and I've been looking for that. Do you happen to have or know where to get the spring rate info for all the various, O.E. suspension levels?
    Is this info helpful?
    GM Stock F-body Springs
    FRONT
    22077189 (39 N/mm, 223 lbs/in) (93-97 V6)
    22133438 (45 N/mm, 257 lbs/in) (98-00 V6)
    22077197 (51 N/mm, 292 lbs/in) (93-00 V8)
    22132887 (63 N/mm, 360 lb/in) (WS6, 1LE)
    REAR
    22077418 (16.9 N/mm, 95.4 lbs/in) (93-97 V6)
    22077421 (19.9 N/mm, 114 lbs/in) (93-00 V8, 98-00 V6)
    22132889 (23 to 30 N/mm, 130-170 lbs/in) (WS6, 1LE)
    http://tech.firebirdv6.com/suspension.html
    That doesn't include the early 1LE springs which GM used on just a few cars (maybe 20?).
    EDIT: Found this:
    "The regular V8s have a 30mm front sway bar (same as V-6 model) and a 19mm rear sway bar. The springs are 292 pounds per inch up front and 114 pounds per inch in the rear. The 1LE and WS6 suspension package has a 32mm front sway bar and 19mm rear sway bar (note, 1993 and early 1994 1LEs got a 21 mm rear bar). The springs are 360 pounds per inch up front and 130-180 pounds per inch (progressive) in the rear (note, 1993 1LEs got the same springs as regular V8s)."
    http://www.f-body.org/oldfaq/html/faq/ch4.html
    It's not precisely accurate with regard to timing of changes, because, as noted by Chaotic Firebird, GM changed the 1LE bars and the springs at the same time.
    BTW, since the early 1LEs were sold for the express purpose of Showroom Stock racing, I've always assumed that GM made the changes after the maybe 20 cars based on track experience.
    2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
    • #17
      It's kinda-sorta helpful but only goes to MY00. The car I'm working with is an 01. Do you know if that spring info carries forward to 01/02?
      • #18
        99+% sure that it does. My "Standard Catalog of Firebird 1967-2002" lists no changes. And this says that it does carry forward:
        http://www.lastofthebreed.com/Servic...ngratedata.htm
        • #19
          wow, now that was an intense debate
          K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
          • #20
            Re: 1LE vs Aftermarket Sway bar &quot;front&quot;
            FWIW, I'll give everyone another data point -- my car is a 99 Camaro V6 convertible, with the following:
            SFC's
            STB
            32mm 1LE front bar
            21mm 1LE rear bar
            1LE end links on all 4 corners
            factory biscuits on all 4 corners
            SLP Bilstein's on all 4 corners
            factory SS wheels with four Firestone Firehawk WideOval's 275-40-17
            alignment to factory specs for a 99 SS conv.
            everything else is original (springs, panhard, torque arm, LCA's, etc.)
            ...no understeer, no oversteer, a bit tight as daily driver's go, but very predictable & so far I've run out of nerve before the car seemed to run out of grip
            :D
            • #21
              Thanks
