I've been leaning towards black zr1's for my arctic white 2001 Camaro and after reading some of the info on the boards was thinking of P255/45R17 on the front wheels and P275/40R17 on the rears. Would all this fit without any modifications? I'm looking at the 17x9.5 front and 17x11 rear zr1's.
Thinking about new rims, a question
Re: Thinking about new rims, a question
The 275/40/17 will be a bit smaller than the 255/45/17. The rears will be about .5" smaller in diameter. In order to get a balanced tire diameter front and back, I would use either of these two combinations:
255/45/17 front
285/40/17 back
245/45/17 front
275/40/17 back
I wouldn't run a 275 width tire on an 11" rim. That's stretching it pretty far especially with a low profile 40-series tire. The 285's would fit better but is still stretching for a wheel that wide. Have you considered going 275/45/17, and 315/35/17? That's what I've got and run with no problems on my '02 Bird(although offset has some to do with it). You'd probably have to modify a bit to fit 315's with a camaro offset(+50 in the rear I expect).
If not, I would just get a set of 4 17x9.5's. You could get 275/45/17's all around and be able to rotate. If you wanted the staggered look, you could get away with narrower tires up front even with the same width wheels all around.
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
