every since i got my new clutch in and it acutally grips like its supposed to, i have had a problem with wheel hop. anything i should look at in piticualr to correct this? thanks in advance, forrest.
wheel hop
Re: wheel hop
Adding a decent pair of LCA's should help remove the wheel hop, if not remove it completely.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
Re: wheel hop
like magnus said a decent pair of lcas, relocation lcas, better street tires torque arrm, just suspension mods like that will help you out. I know for tires though I churp 1-2 shift cause of the regular tires in the back and when I had my nittos I didnt so that comes into play as well...but just do moderate suspension mods and you will be fine2002 Firbird, <br />STS GT35mm-61 Turbo, HP Tuners, 3.73,UMI LCAS,UMI Panbar<br />Nitto NT555R P245/50R16 96v, NGK spark plugs t55, transgo shift kit, Jet servo
