wheel spacer troubles - FirebirdV6.com/CamaroV6.com Message Board
  • wheel spacer troubles
    i put wheel spacers on only my back two tires on the passenger side it looks perfect but on the drivers side its sticks out about a half inch more than the other is there any reason why it would do this? the spacers are both the same size
    97 Camaro 3.8 5 speed<br />Cat Back <br />SS rims<br /><br />Beauty is in the eye of the beer holder
    Re: wheel spacer troubles
    Thats weird? is your car dropped? if its droped enough is moves the axle to the drivers side slightly becouse the panhard rod has to pivit . hod big are your spacers and what wheels you got?
      no its not lowered but i want to, they are 1.25 inch spacers and i have 10 spoke ss rims
        I dont know but when I got my TT2's on the shop had to use a spacer but only on the left front. I thought that was weird.
        1998 Camaro V6 \"Black Mamba\"<br />Y87<br />Whisper Lid w/ K&N filter<br />Flowmaster American Thunder<br />Numerous appearance mods.<br /> <a href=\"http://www.cardomain.com/ride/2154172\" target=\"_blank\">Car Domain</a>
          You will need to center your rear end. I also highly suggest getting rid of those wheel spacers if you can.
          btw. Why are you using spacers on a GM stock F-Body rim? They are unnecessary.
          Teh Cars:<br />2002 Firebird V6<br />1997 Camaro SS 30th <br />1991 Firebird V6<br />1989 Firebird Formula<br /> <a href=\"http://www.cardomain.com/ride/855002\" target=\"_blank\">http://www.cardomain.com/ride/855002</a>
            Where did you get your spacers? I tried to order the 25mm Eibach spacers, but was told that they were still in development(???)
            Custom interior...
            TEAM NoVa
              [QUOTE=phantomzer0]You will need to center your rear end. I also highly suggest getting rid of those wheel spacers if you can.
              QUOTE]
              Why highly suggest something wrong with spacers??
                I've never personally used them, but I've read alot of horror stories off of ls1tech. I suppose it could be different with the differences between horsepower, but it doesn't sound pretty.
                I still don;t understand why you would even use them with stock GM rims for an F-Body....they are useless.
                  to suspension
                  Visit My F-Body Page
                    i got emm on ebay, how do i center my rear end???? i got them to sick my back wheels out of the fenders more, before they when in the fender now the passenger side comes jus to it and the other sticks out of the fender a lil less than 1/2 inch ...... what kind of horror stories????
                      it puts more shearing stress on the bolts. meaning if ur car was built up enough, u could break the bolts and lose a wheel. also, if there's not enough thread engagement between the bolt and the lug nut, u could rip the threads off and lose a wheel that way. I think 1/2" is the most u'd ever wanna go, and definitely get some ARP extended lub bolts.
                        i think he used adapters not spacers for 1.25 inches!?! but i bet thier aluminum, is this like what you used? you center the axle with a adjustable panhared rod
                          yah those are the ones i used, alrite ill try to center it thanks
