do i need low profile tires... - FirebirdV6.com/CamaroV6.com Message Board
  • do i need low profile tires...
    if i am putting 17" rims on a 2000 camaro that has stock 16's?
    Re: do i need low profile tires...
    go here: http://www.miata.net/garage/tirecalc.html
    Custom interior...
    TEAM NoVa
      thanks T-mill. from that, i realized that there won't be that big of a difference. the only thing i'm worried about is if a regular sized tire would rub when i turn or not. i'll ask the guys at the place where im getting them put on
        a lot of V8's came with 17's so no it will not rub. normal 17" tire size is 275/30/17 I think. but if your using a rim thats less than 8.5" wide I don't think you can use a 275. might have to go with a 255 instead.
        95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
          What is the stock 16" tire size? anyone? The hideous hubcap thing.
          http://www.cardomain.com/ride/2287597
          :( SOLD! NO LONGER A CAMARO OWNER :(
            lol ive got the snowflake rims (stock). not sure of the exact size
              Stock steel w/ hubcap = 16x7
              Stock aluminum = 16x8
                i think 235/55/16
                  Sorry, for some reason, half of my previous post disappeared. Anyway, here's what the other half was supposed to say:
                  Stock steel w/ hubcap tire size = 215/60/16
                  Stock aluminum tire size = 235/55/16
                  Although, some people have varying sizes in between(225?), but these two sizes should cover the majority of stock tire sizes.
                    275/40/17
                    Raven
                      275-40-17
                      Left turn Clide.
                        thanks i dont know much about tires and sizes... obviously...
                        i took it to tire kingdom... the guy recommended bf goodriches right off the bat and he said something about 215.
                        that's all i know.
                        i'm sure they know what they are talking about. at least i hope so.
                          I called and they said the ones they were putting on were 215/40/17.......
                          I looked at that on the tire size calculator and there was a huge ****ing gap between the fender and the tire so I called them and told them I have no plans on lowering my car.... so then the guy recommended 245/45/17......
                          so i told him to switch them to that size instead.
                          okay or not okay??
                          Looks exact same size as my stock on the tire calculator so there wont be a huge gigantic gap.
                          I assume they know what they are talking about... but you know what happens when you assume
                            you would probably run into traction problems with tiny tires like 215s.
                            and even if you didnt, they would look wrong.
                            245 is a good width for 17s.
                            i have 275s, i love the wide look.
                            imo i wouldnt get anything smaller than 235.
                            <a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
                              the steelies? 215/60/15
