what would you guys estimate the average cost of an install of all these would be? I would normally do everything but the tires, however, just doing the heads and cam 3 weeks ago discourages me quite a bit, thanks.
shock's,springs, struts, lca's and tire install
Re: shock's,springs, struts, lca's and tire install
where are you located at? I had a guy from texas right outside dallas do mine for 180 total....I had Bilsteins installed with lowering springs, LCA's, and panhard...he had a spring compressor and everything at his house with an AIR GUN!
well tires I cant do, since I have no way to mount them on the rims, LCAS should be easy you are right, but I was under the impression springs and shocks were hard to do.
do the lca's and rear shocks yourself. they're cake. id say about 250 for the tires and struts/springs up front.
