Remedial question on suspension mods... - FirebirdV6.com/CamaroV6.com Message Board
  • Remedial question on suspension mods...
    Well, my remideial question of the week is as follows:
    Here is the scenario, I am driving along the interstate and taking an exit ramp. The ramp is a circular ramp with a gradual decline. The off ramp is also a bit worn with bump, holes, etc...While making the turn at the posted speed (35mph) I notice that as I hit a bump in the road, the car feels as though I am sliding a bit. Not so much that I feel like I am loosing control, but enough to be noticed and aware of.
    Would modifiing my suspension help get rid of this "sway" or loose feeling as I drive over these bumps in the road?
    If so, what type of mods should I consider making?
    As always, thanks for your time and input!
    Re: Remedial question on suspension mods...
    that sounds really weird man... should not feel any sliding???? might be leanin wid it lol.. but should not be sliding... if the sway is what u feel... u should do front and rear sway bar.. and a panhard bar..
    Read my liscenceplate Frame Corvettenet.com<br /><br />2000 Y87 Pewter A4<br />MODS:Tuned,3.73, SLP CAI, K&N offroad aircharger intake,Custom Plexi-glass Ram Air Box, Red Caliper ,Stage 2 Jet PCM, 3 inch Borla XR-1 Catback,ZR1 Rims Kuhmo 712s,MSD 8.5 SC wires
      it is probably a normal thing. remember, you car is wanting to keep going straight, when you hit the bump, the wheels momentarily come off the ground and keep going straight. so, when you hit the bump, your car really is sliding, i don't know how to alter your suspension to fix it.
      2000 3.8 A4 Pewter Camaro
        lol dont hit the bumps anymore lol...it wouldnt hurt to upgrade the suspension...i did my panhard bar and it made a difference
        87 Firebird RIP
        96 Camaro RS RIP
        94 Patriot Red 1LE Z28 - Sold
        02 WS6 TA - Sold
          _First_ thing to consider is shocks. If yours have >50K miles on them they're a likely culprit.
          This will always happen a little with a live axle car. Good shocks can lessen it, bad will increase it. Panhard rod, chassis stiffness, and worn suspension bushings can also be a factor, but the shocks are by far the place to start. Swaybars aren't a factor in this.
            I agree with Bob. A good set of shocks will help keep your rubber on the ground over rough surfaces.
              I went ahead and rebuilt my front end when installing struts, springs, sway bars, and polyurethane bushings; and found several front end parts that were wore out like the tie rods and ball joints. It drives like a different car. If you can put your car on a lift, you can make sure all of your font end parts are tight.
