drilled/slotted rotors - FirebirdV6.com/CamaroV6.com Message Board
  • drilled/slotted rotors
    which way does the pattern on drilled/slotted rotors need to face?
    1994 Camaro 3.4 L V6 <br />2.5\" Flowmaster 80 Series American Thunder Exhaust<br />SLP Cold Air Intake<br />Sony Head Unit<br />Pioneer Midranges<br />2 10\" Sony XPlod 1100 W Subs<br />Power Acoustiks 980 W Amp<br /> <a href=\"http://www.cardomain.com/id/heartbeat_of_94\" target=\"_blank\">http://www.cardomain.com/id/heartbeat_of_94</a>
    Re: drilled/slotted rotors
    What? It should be obvious which rotor goes where... cuz you can't put them on backwards....
    Originally posted by SSMOWS6
    i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
    R.I.P. '07 Pats
    Still... 18-1 > 1 and done
      put them so that the slots do not look like a rip saw cuttin the pavement
        oh really? i didn't know that!!!
        duh! but you CAN however have the angles for the slots and the drill holes to where they are "ripping into the pavement" when going forwards or to where they are "rolling" over it.
        so at the top of the rotor, the slots should be going at a downslope from right (highpoint) to left (low point) as if they are "rolling" over the pavement?
          <edit> Further confirmation from Brembo FAQ:
          Additionally, all of Brembo's slotted discs are directional as well, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first. Please see figure.
