bolt pattern - FirebirdV6.com/CamaroV6.com Message Board
bolt pattern
  • bolt pattern
    Has the bolt pattern of the firebird changed over the years? because i could get a good deal from a friend on a set of radials he had on his '76.
    '96 Trans Am M6:) Cam, lifters, 1.6rr, lt4 springs, 4 bolt mains, long tubes, TDs, short throw...etc
    '99 Firebird SOLD 1/4 mile 15.4 @ 86
    '66 Ford SOLD
    Re: bolt pattern
    It should be the same
      Re: bolt pattern
      backspacing is a different matter. 2nd gen wheels fit on a 3rd gen easy. for 4th gen, you'll need spacers.
      2013 Ram 1500 Big Horn
      94 comero 3.4
        Re: bolt pattern
        If you put 3rd gen or older wheels on your 4th gen they are going to stick out way past the fenders.
          Re: bolt pattern
          yup, musta been the 3rd gen imme. 1st gen, iirc has same setup w/the next two incarnations.
          94 comero 3.4
            Re: bolt pattern
            I wasnt going for looks so i dont care if there way far out bc i would only use them at the track, there good drag radials. I have my z06 rims and ZRIs for the street
            '66 Ford SOLD
