Help!!! Lca Relo Brackets - FirebirdV6.com/CamaroV6.com Message Board
  • Help!!! Lca Relo Brackets
    Hey everyone i need some assistance on trying to install my LCA relo brackets....I have tried today and cannot seem to figure them out...The place i bought them from did not come with directions or anything..
    These are the ones I have..
    http://www.hotpart.com/index.php?p=show&id=139
    I bought those specifically and didnt get the instuctions like stated...
    But has anyone installed these or installed any on there car that can post pics of them so i can get the jist...Or know the correct directions to do so?
    Re: Help!!! Lca Relo Brackets
    tonight anyone??
      these are bmr bolt-ins, but they should be the same.
      94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
        did you have to do any modifications? Such as use the hack saw or anything?
          I think thats the same ones I have , I think I had to do some grinding , I 'll take a look tomorrow afternoon.
            As the pictures show, they go in front of the shock mount and around the lca bracket on the rear.
            If you have a 93-97 they go on without modification. If you have a 98+ the parking brake cable bracket is mounted in the way.
            The only thing I did not like about the hotpart brackets is they only came with one pair of bolts and you really need 2 sets. You can get away with reusing the stock bolts, but with the extra width of the relocation brackets they're a bit short. If you don't use the washers you barely get enough thread to get them snugged. I had to order another two 10.9 grade bolts 12mm x 1.75 x 100mm and nylon lock nuts and washers from boltdepot.com
              Now i know this is an old thread but, What did you guys do to put the lca relocation brackets around the parking brake cable?? I'm in the middle of this and need some guidance
