17x9.5 wheels +54mm offset - will they fit? - FirebirdV6.com/CamaroV6.com Message Board
  • 17x9.5 wheels +54mm offset - will they fit?
    Will these wheels fit properly with 275/40-17 tires on a 97 Firebird V6?
    Re: 17x9.5 wheels +54mm offset - will they fit?
    i am pretty sure you will have no problem, mine are 9.5 wide and a +56mm offset. no problems.
    1997 Camaro LS1 RS
    1994 Camaro - Sold
    1999 Trans am Vert - Sold
    A Few Mods....
      Thanks Tom. What is the general rule with offset, does it mean the higher the offset, the farther out the wheels are from the wheel well?
        there was a thing about it on the powerblock i forget how it worked. try to google it.
        1997 Camaro LS1 RS
        1994 Camaro - Sold
        A Few Mods....
          The bigger the offset (in the positive direction) the farther IN the wheel will be - a lower numbered offset will stick out further.
          <a href=\"http://www.cardomain.com/id/vracer111\" target=\"_blank\">My \'98 Camaro</a><br /><br /><a href=\"http://www.honda-tech.com/garage?cmd=viewcar&id=1223\" target=\"_blank\">My \'98 Tacoma</a>
