I swore I saw one for an F-Body. I want a full coil-over kit all around; I see they have that racing setup one for like $2600 but thats to much and its also for racing 650lb front springs... Then theres the QA1 or Q1A front kit which is affordable at around $500 for the front but I want a coil-over setup for back also to match the fronts. I could have sworn I saw one but I was goggling for a while the other day and could find one for a 4th gen rear.
Rear coil over kit?
Re: Rear coil over kit?
The QA1 system is made for drag racing. Ground Control makes a coil-over system for the F-Body's: http://www.ground-control-store.com/...hp/II=21/CA=67
Originally posted by Chaotic FirebirdThe QA1 system is made for drag racing. Ground Control makes a coil-over system for the F-Body's: http://www.ground-control-store.com/...hp/II=21/CA=671997 Camaro v6 3.8 <br />Bone Stock, just a little slower then most station wagons.<br />**Either the slowest SS or the prettiest v6**
http://www.neweraperformanceparts.co...47&NID=2387522
There's 2 kits here, a full coil-over conversion, and a coil-over plus 4-link conversion.2001 Arctic White Firebird<br />More mods than I\'m allowed to list!
The ground control kit has adjustable perches for both the front and rear springs.
If you don't know what spring rates you want, don't guess. Get them from someone like Sam Strano at stranoparts.com and he'll talk with you and help you decide.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
