woow what an improvement. 32mm s.b. and polyurathane bushings and endlinks. worth my 65$ spent. althoug i feel slightly more body roll when i makel eft turns... is that usual or di i under tighten/overtighten something?
pics:
i know... the endlinks are upside down
i have the same sway bar and i don't have a difference in body roll from L to R. don't know why that would happen, maybe check the torques on everything? maybe worn out springs or shocks?
how much of a diffrence did this make for you?
i dont want to buy springs or anything like that untill i get rims... but i wasnt sure if buying a new sway bar would be worth it
what size rear bar are you guys using with the 32?
K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
im still using the stock 3.4 rear bar (which i believe is 17mm. the 3.8 is 15mm iirc.)
its not terrible but i am having rear traction issues, especially in the rain.
i just cant find a good deal on a 19mm or 21mm bar.
If you're having rear traction problems now, installing a bigger rear bar will make them much worse. A bigger rear bar reduces rear traction. The jumps of 2mm are relatively large on the rear.
i dont really know what the effect of the rear sway is on the suspension to be honest.
but i wasnt sure if it would help or hurt my problem. but i wasnt really expecting it to solve it. im getting the bmr lca relocation brackets which should do the trick. (since the problem appeared after lowering.)
<a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
I have the 32mm BMR (f) and 21mm (r) BMR sway bars. When I was figuring out what I wanted a long time ago v6Bob said the same kind of things, and I listened to some of them. I got ws6 rims too. I did that trying to make it more stable because v6Bob said that the 21mm was too thick for our cars. I love the way my car handles with the way I have it. If I go around a corner and try to make the back end step out it does smoothly and predictibly. I feel that my car handles very well and would recommend the setup. But without the wider tires I can't say either way. I would listen to v6Bob, the suspension threads I've read with him in them show he knows what he's talking about.
