upgrade 97 brakes - FirebirdV6.com/CamaroV6.com Message Board
upgrade 97 brakes
  • upgrade 97 brakes
    I want to upgrade my 97 brakes,probably will use 98+
    Do I really need to do the rears too?
    Re: upgrade 97 brakes
    No. I did the 98+ fronts and have the stock 96 rears.
    Raven
      Are the 98+ fronts bigger?
      whats the difference.
      '95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
        Yes. A little over an inch larger rotors. Twin piston aluminum calipers, instead of single piston iron ones. And larger pad surface. I have the 98+ front setup as well. It's also 4 pounds lighter per side.
        I swapped in a rear that has the 93-97 rear discs.
          Ahhh, thanks a lot FunkZ.
            Ho ho, late model F-Bodies FTW
            Originally posted by SSMOWS6
            i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
            R.I.P. '07 Pats
            Still... 18-1 > 1 and done
              :spank:
              I'd rather get some drilled and slotted rotors!
                You could upgrade to 98+ and get drilled and slotted.
                Originally posted by kala
                TEAM BLACK!!!
                parting her out
