i think i could figure out, but if someone knows of a write up or has done one lets hear from you
write up on K-member install
Re: write up on K-member install
I haven't really seen a write up on installing a k member, I have seen pics of installed ones and people talking about the fun times they had trying to put them in.
i just did it but i didn't take any pics........ i guess i could give you a run down but i'm a lazy.......
lol......
what you want to know?www.turbov6camaro.com
1997 3800 Series II Camaro
Originally posted by UDLOSE98Basically i see i think 8 bolts and there are a few brake lines that need to be unbolted form the K, anything else? I took the tires off as well. how long did it taek you?
1. dont try short cuts it will only take longer!!! if you have the motor in then umm good luck lol
6 bolts hold it to the frame of the car (3 each side)
4 bolts hold the lower Arms on (2 per side)
the easy way is to drop out the front spring/shock, undo swayl bar.... leave stearing rack unbolted from K
this lets the front ARM move free so you can line it up when putting the new one inwww.turbov6camaro.com
Originally posted by UDLOSE98the motor is out, **** didnt realize ti was that involved...now is it worth it............www.turbov6camaro.com
Originally posted by viper04afyou you basically have to take apart the front suspension to to do it...... i save 30# buy moving to it and it is MUCH smaller give to 2 inch more ground cleanance for my DP to run under there :)
Originally posted by UDLOSE98yea i figured it would be more clearance for the DP, well I have to wait for the transmission anways, so i might as well.
oh yeah you will need 6 bolts to hol it to the car the stocker do not work at least on my PA member they didn'twww.turbov6camaro.com
I tried to install my PA K-member today and the bolt holes on the passenger side do not match up with the bolt holes in the engine mount pad. Anybody have any experience with this problem?
Did you utilize the factory motor mounts and pad?
Anybody have pictures showing the proper bolt placement on the K-member?
Yes factory mounts are used , when installing it don't tighten any of the bolts down all the way until all bolts are in , its funny I bought Uoluses PA K member and it bolted up fine thats from way back then, so there new ones should bolt up even better, they had some issues with them when they first came out, but mine fitted fine, took 4 hours to do the tub K and A arms. But I had it at my Dads GM work place and some mechanics doing just about all the work. I'm going to be taking off my Y pipe and prefitting my oval turbo Y pipe to the front either tonight or tomorrow night so I can take pics of what you want just let me know.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
