Rim width - FirebirdV6.com/CamaroV6.com Message Board
Rim width
  • Rim width
    What is the rim width and off-set on a stock 99 Firebird spoke wheel?
    Re: Rim width
    Stock alloys are 8", i'm not sure about the offset... 4.5? Eitherway you could always search for it :tup:
    Originally posted by SSMOWS6
    i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
    R.I.P. '07 Pats
    Still... 18-1 > 1 and done
      Re: Rim width
      you are probably better off checking out the appearance, or the suspension section, then here either way.
      stock wheels are 16X8s, SS/WS6 wheels are 17X9
        Re: Rim width
        Thanks fo the info. I did a search, but could not find any posts on the offset. Thanks for the help.
          Re: Rim width
          the offset should be front - 35-56mm
          rear - 40-60
          i found all the stock wheel info like this on an rim website they even include stuff like center bore and bolt pattern measurements and proper lug sizes
