not at home(read no haynes) , and no luck searching "caliper rebuild". doing the ellis juan type caliper/rotor upgrade & have the calipers in pieces. Anything special besides what should be the obvious on putting the parts back together?
rebuilding front calipers
Re: rebuilding front calipers
i know your back i ll sell you a good set there red 20.00 there good came of my car when i did the LS 1 conversion if your just going to rebuild blow the cup out get new rubber rings put a light coat of brake floid on them but back in same with the cup put a light coat of brake fluid on it and slide back in thats how i did my LS 1 calipers96 Z LT 1 6 SPEED 3.42 T TOP<br />LS1 BRAKE UPGRADE<br />LS1 DASH AND CONSOLE CONVERSION<br />5.0 SHIFTER<br />52 BBK <br />ROLL BAR<br />LT4 KNOCK MOD <br />REAR SEAT DELETE<br />ALUMINUM DRIVESHAFT SITTING ON SHELF
the setup I have have has the brackets/calopers/steering knuckles poweder coated body color. I'll bring a set & show you when I pick up the headlight covers.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
